fog lights
Old Dec 8, 2002 | 03:48 PM
robstaxi's Avatar
fog lights
I'm having problems with my fog light's burning out to soon..they only last for about a month..then I have to replace both of them (both bulbs burn out at the same time....What could be causing it
Old Dec 8, 2002 | 04:32 PM
mville656's Avatar
Are the bulbs dirty when you replace them? Do you think they are getting wet? If the seal on the bulb is bad or if the lense is cracked, that will make the bulbs burn out faster. Do both bulbs burn out at the same time?
Old Dec 8, 2002 | 05:09 PM
robstaxi's Avatar
yes both bulbs burn out at the same time
Old Dec 10, 2002 | 06:33 AM
2stroked's Avatar
Another thing that will burn your halogen bulbs out quickly is if you touch the glass during installation. Believe it or not, the small amount of oil on your fingers will cause a hot spot on the glass and cause bulb failure, Do not touch the glass during installation. I'd also check to make sure you're not getting water into the housings by not fully installing (turning) the bulbs.
Old Dec 11, 2002 | 12:58 AM
robstaxi's Avatar
I already know that...don't you find it strange that every month I have to replace both bulbs....I have the lighting front bumper on my truck...
Old Dec 11, 2002 | 06:33 AM
2stroked's Avatar
I find it VERY strange. One thing you might want to do - and this is a long shot - is check the voltage that's actually getting to the lights with a meter. You might find a surprise there. I'd also recommend checking for a good ground. Halogen bulbs are very sensitive to low voltage situations.
Old Dec 12, 2002 | 12:51 AM
robstaxi's Avatar
I have noticed that the daytime running lights don't work will this cause a problem with the fog light's
Old Dec 12, 2002 | 09:32 AM
Johnny Mo's Avatar
What about vibration?
I've had lights blow due to excessive vibration. Seems odd that they both blow at the same time, but that might be something to check.
Old Dec 13, 2002 | 02:07 AM
robstaxi's Avatar
I have also noticed that the light switch gets very hot I'm not sure if it's from the heater or the switch is over heating...has anyone experance this problem with there F-150?
Old Dec 13, 2002 | 02:08 AM
robstaxi's Avatar
I was just woundering if it was wired up wrong or something
Old Dec 13, 2002 | 02:54 AM
snappylips's Avatar
If you have had a recurring problem blowing both fog bulbs, then the DRL's have started acting up or stopped working, and now you notice that the switch is getting hot, I think almost certainly that you have a H.L. switch causing a resistance problem in your lighting circuits. Sounds like time for a new one. Was anything done to modify the wiring (foglight mod). If so, that could be causing the problem. Not the mod, but the actual work may not be up to par. Maybe? Hopefully you caught it before it starts melting your harness'.
Keith
