Fuse Box
Old Dec 6, 2002 | 07:34 PM
cfoley's Avatar
Fuse Box
My 98 F150 Flareside that I bought used seems to be going thru some midlife crisis. I need to find a fuse diagram.
my interior light stays on and the bell does also causing me to not want to even start it because it drives me nuts.
anyone got a pic of the fuse box or a site where I can see it?
Old Dec 6, 2002 | 09:53 PM
Silver&Blue's Avatar
Spray a good thick coating of WD-40 in the door latch and work the door and soak it again. See if this helps. I am thinking dirty contacts on your door latch switch. Thats what it took on the SD when I had the same exact prob.
Old Dec 27, 2002 | 09:30 AM
medic42's Avatar
Fuse box
Did you ever get the diagram for your fuse box? I am also looking for one...
Alan
medic42@dlcga.com
Old Dec 27, 2002 | 09:34 AM
flafonman's Avatar
I've got my Haynes manual handy, what do you want to know?
Old Dec 27, 2002 | 10:10 AM
medic42's Avatar
The fuse panel is not marked as to what fuses go to what. There are 4 relays and 25-27 fuses. Nothing is marked.
Old Dec 27, 2002 | 10:38 AM
flafonman's Avatar
The fact that my 98 didn't have an owner's manual was the reason I came to this site in the first place. I bought one off Ebay for $15. I would by useful if the cover of the panel had a label to identify which fuse related to which circut; however it does not.
Wiring diagrams are considered to be copywrite protected (unless you draw them yourself I guess) , and until I take the time to copy the entire fusebox code from the manual into something that can be posted you'll have to settle for one at a time.
Here's a freebie:
Interior lights Fuse 14 (15A) drivers side fusebox in cab
Power windows Fuse 25 (30A) in power box under hood
Old Dec 27, 2002 | 09:30 PM
medic42's Avatar
Thanks for the reply. I replaced the interior light fuse and they started working. The funny thing is, so did the power windows. Wierd, but as long as they work...Thanks
Old Dec 28, 2002 | 10:51 PM
pw1981's Avatar
Download Glove Box manuals for all FMC cars and trucks 1996-Current here:
http://www.qualitycareservice.com/
Old Dec 30, 2002 | 08:11 AM
medic42's Avatar
Thanks, that's just what I needed...
