Big Electrical Problem Wipers,4X4,Windows
Fuse Problem
I have a big problem with my 97 F-150 Lariat..Don't work the Power windows,wipers,4X4,Interior lights..When i try to turn on the Wipers dont work but i can hear a little noise in the motor....I detect one fuse that always is damage...I went with the tech and he said that i have a big electrical short but i need to pay 250 dlls to fix that plus the part.....I dont know exactly the fuse diagrams...
If some body has the fuse Config. please send to ramon_hernandezc@yahoo.com
Please advise
Baja 2002
Please advise
Baja 2002
Hi Baja Welcome!
I forgot the link...i think it was posted on this bd. Maybe a search or someone that knows will direct you. There is a site for that.
Also as i recall someone posted here about similiar problems. In their case i believe it was water leaking in and somehow got into the fuse panel/wiring or? Other times just a bad fuse, but didnt blow after replaceing it. I think a short causes it to keep blowing. That can be a real headache to find.
That may not be your problem? The fuse that always gets damaged "blown"? Whats that fuse for...or is that what your trying to find out because you dont have the manual? I assume thats the one thats causing the power loss?
The tech. says $250 plus parts? What parts? I guess that means hes confident he can find and fix it for price he quoted?
Good luck...OT
Good luck...OT
Water leaks in , either A pillar, or windshield seal, or wherever. Big problem is water gets into GEM module, and main fuse panel/relay panel under dash, causing all sorts of electrical problems.
Problems from things not working, to fuses blowing, to things staying on all the time.
Replaced lots of gem's and panels for that concern, AFTER the water leaks were taken care of.
Don't know how anyone can quote exact prices, unless they work both sides of the parts/service counter.......who knows.
Good luck. Have fun.
Guys thank for your advice...
Today i buy the haynes Repair Manual for my F-150,4x4 Lariat 97 and is not to clear with the fuse layout....SO i'll try to fix my car before send the car with the tech.....If somebody has a more clear picture of the fuse's Layout..I'll appreciate..
Thanks in advanced
Baja2002
Thanks in advanced
Baja2002
Hi,
I put them on an album.
Just go there and let me know what you think
https://www.f150online.com/galleries...w.cfm?num=2770
Alex.
Alex.
One more thing...
Don't buy Hayes, buy CD on eBay
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1869874379
Alex.
Alex.
AB,
Thank you sir...You are so kind...I already fix my problem..Know i have working the Electrical windows,Wipers and the interior lamps. I found one electrical short and one connection loose in the distribution center panel and one fuse damage in the hood.
And i pay 10 bucks....In some fuses.....
I receive the F-150 Manual in a PDF file from one good peopple (3000 Kb)in this forum...
This is a great forum..
Baja2002
Baja2002
