Too Many Wires!!
Old Oct 16, 2002 | 03:48 PM
UrbanCowboy's Avatar
Too Many Wires!!
I have a ton of electronics hooked up directly to my truck battery. This includes my MSD ignition, 7 KC Daylighters, Tachometer, etc. I was just going to add a couple more lights on my truck, and I was thinking.....There's got to be a better way to wire all this. I have way too many wires connected directly to the positive terminal of my battery. Does anyone here have a better idea on how to power all these systems? Thanks!!!
Old Oct 17, 2002 | 01:26 AM
pw1981's Avatar
Connect an auxillary fuse panel and fuse each of the wires. Automotive store should have a wide selection of them to choose from. Having them off the battery and separated in a panel is much safer. I reccomend bolting the aux. panel to the lead line on the main power box rather than to the battery. Keeping the battery clean and clear is a good idea.
Old Oct 17, 2002 | 08:13 AM
AB's Avatar
AB
Thumbs up The Power Distribution Terminal (PDT)
Hi,
There is a nice article in "Tech Articles" section called something like "So you want to add some electrical accessories...".
The continuation if it is here
http://www.geocities.com/gdgo/f150a2.htm
You might want to check PDT...
That's what I've done.
Alex.
Old Oct 17, 2002 | 08:30 AM
AjRagno's Avatar
Re: The Power Distribution Terminal (PDT)
Alex.
Yep. Me too. It's a perfect source.
Old Oct 17, 2002 | 11:54 AM
Thanks Guys!
Old Oct 17, 2002 | 12:03 PM
BigTuna's Avatar
Can't delete this post, so pretend this doesn't exist
Old Oct 20, 2002 | 04:27 AM
SVT2B's Avatar
there is no need to connect to the battery . Just to the right of the battery on the firewall is the power block . You can attach there without any problems . Remember to fuse everything .
