Fog LIght Wiring HArness
I bought my 97 F150 used and the person had installed the fog lights but there's no wiring harness going to it. The Ford dealer in Germany has tried unsucsefully for months to get the wiring harness but the wron g on keeps coming in.
Anyone have a good part number or source for this ?
Mike
Mike
I did a search and found a post from January 2002 called "adding stock foglights" Check it out-the harness he used P/N: XL3Z 15A211 BA is for trucks that did not come with them factory installed.
Hope this helps.
Hope this helps.
Forget the harness...
go to the auto parts store and buy a relay kit made for lights. The kit will have a 30 amp relay, fuse, wire, etc. The relay has four connections (one to the battery, one to the lights, one to a 12+ volt source, and the other to ground. The hardest part is finding a 12+ wire that is on when the key is on and of when the key is off. Otherwise, it's apiece of cake.
This way you will have your lights working in no time without having to stress about some Form OEM wire harness. Good luck!
