Headlight Problems
Old Jun 19, 2002 | 11:36 PM
LoCo F150's Avatar
Headlight Problems
WHEN EVER I PUT MY HEADLIGHTS ON...THEY START TO DIM AND THEN TURN OFF. IF I WIGGLE THE TURN SIGNAL SWITCH A LITTLE THE WILL COME BACK ON OR WILL TURN OFF. ANYONE KNOW WHAT I NEED TO DO TO FIX THIS?
Old Jun 20, 2002 | 10:25 PM
Wino's Avatar
those after market bulbs play hell with the multifunction sw. mostly if they are a higher watt than stock. or its just poss your sw is going out. the wires also will get a bad connection at the sw to. just from the tilting of the steering wheel. it will flex the wire at the connector. pull the cover inspect the wires, may remove the sw and make sure those terminals are ok. remember those head light sw's and multifunction sw's are not made for those high watt bulb's. you might want to wire in some relays. if you havent allready. good luck.
