? on installing PIAA 40's
I am waiting to get back my PIAA air dam from being painted. I purchased some PIAA 40's to go into the outboard holes. So here is my question. When I install these lights, do I just use the wires that go to my factory driving lights, or do I rewire everything? I want to be able to use the factory switch. Or do I run the factory wires to the relay?
Have any of you guys installed either the air dam or these lights? Thanks for your help. Eric
Eric, I think you emailed me about htis but if not, the way I would recommend doing this is NOT to hook up to existing wires, but if you want them to come on with your stock switch, hook up the wiring diagram accordin gto the manufacturers recommendation and then take the hot wire that is going to your switch and splice it into the wire for your fog lights. That way, all the lights are getting sufficient power, they come on with your stock switch, everyone is happy
