power windows- how much?
hey guys,
i am getting really tired of rollin my windows. i am curiouse as to how much it would cost to have power ones installed. my truck info is in my sig. thanks for any info you guys have.
Try here
http://www.autoloc.com/
http://www.autoloc.com/window.html
If you do a google search you can find others that are somewhat cheaper.
Just pop the window handle off and leave the bolt in. A small electric drill with a hexhead and you will be faster up and down than the fastest power window.
I saw them test the windows on the assembly line. The worker used a drill on the manuals and it was up and down in less than two seconds.
Originally posted by Raoul
A small electric drill with a hexhead and you will be faster up and down than the fastest power window...
I did a search on small electric drills with cigarette lighter as power source, no hits. My rechargeable Makita can only handle so many up-down window cycles. Difficult to shift/turn/open window all at the same time too. Can anyone help??
Wreckers
Go see your local wrecker, look for an F150 with power doors and windows with the same interior color as your truck. Hopefully you can get a deal if the doors are cosmetically damaged (keyed, badly dented, bullet holes). Make sure to get the wiring from the door to the fuse panel, with all connectors.
John
John
Thanks for that link to autoloc beast, i think that will come in handy
