Turn Signal & Windshield Washer Q
I am thinking about buying a friend's 98 F-150 Supercab, and it has one annoying quirk: sometimes the windshield washer feature only works when the turn signal is engaged. Obviously (?) this is a problem with the multi-function switch on the steering column. Ford wants a princely sum to fix it (of course), and I was wondering how much it would cost to do the fix myself, and how easy it is to access the switch in question.
Thanks, Mike |
It should involve only removing the upper and lower column covers and tilt lever to axcess the 2 screws and wiring harness for the MFS.
Sweet. No need to pull the steering wheel, then?
Thanks, Mike |
