Replacement door & ignition key's
Old Feb 25, 2002 | 10:19 PM
Lou Colmo's Avatar
Hello all, Just picked up a 98 explorer xlt for my wife, the problem is it only came with one key.This vehicle has the remote entry keybob and keyless entry. Does anyone know if the key's for this year and model are the chip key's? if so do i need to go to a dealer for this? Thank's in advance.
Lou
98 F150 XLT s/c 4.6 auto 2 wd (His)
98 Explorer XLT 4.0 auto 4wd (Her's)
Old Feb 25, 2002 | 11:14 PM
LarryS43's Avatar
Smile
Lou,
Contact this guy : joefriday2@aol.com
I don't know him personally, but he sells PATS keys on eBay for $13 plus shipping and has answered questions for me before about various Ford vehicles. Good luck.
Old Feb 26, 2002 | 01:14 AM
Dennis's Avatar
If the key head is big and has a rectangular plug on the end, it's probably a PATS key.
You can have a regular key cut for a buck and try it. If it doesn't work, then you'll need a PATS key. Don't throw away the regular key because you can keep that in your wallet and it will get you into your vehicle if you happen to lock the key inside.
Old Feb 26, 2002 | 08:46 AM
buschman's Avatar
'98 Explorer does have PATS. Since you only have one key you will need to go to your dealer to get the second key programmed. The method the Owner's Manual gives for programming keys yourself requires you have two already-programmed keys.
Old Feb 26, 2002 | 08:12 PM
Lou Colmo's Avatar
Thanks to everyone"s replies. Turns out i do have the PAT key. Took it to Pundmann Ford in St. Charles Mo. and had 2 keys made for $74, not to bad i guess. Thanks again, Lou
Old Feb 26, 2002 | 09:06 PM
F250-lariat's Avatar
Programing Remotes
Programing Remote
OK I just got another remote door lock key fob, now I am having trouble programing it for my truck. I was able to program the new fob - but now my old one wont work.
Heres the technique I used,
cycle ignition on/off 8 times within 10 seconds then press the lock button on the remote which you want to program.
The problem I am having it with programing 2 remotes !!
Any help is appreciated
Old Feb 27, 2002 | 12:26 PM
buschman's Avatar
You have to reprogram BOTH remotes again. When you programmed the new remote it deleted your old one.
After you cycle the ignition on and off 8 times, press a button on the first remote, the locks will cycle - then press a button on the second remote, the locks will cycle again. Voila, problem solved.
Old Mar 14, 2002 | 03:30 PM
bobby tingle's Avatar
Hey Lou Colmo, Email JoeFriday2@aol.com he will ship you an extra key for $20.00 Plus $5.15 shipping. You program it yourself.
takes half a min. with the instructions he sends you. So for $25.00
you have a extra one.
Old Mar 15, 2002 | 08:07 AM
SilverFlareSide's Avatar
Talking Lou Colmo:
nice to see another ford fan from missouri!
