Door ajar
Old Feb 20, 2002 | 06:24 PM
qxeplt's Avatar
Door ajar
Well, I tried to lube my switches but it still acts up. I suspect it's in the relay, not the switches in the door cause when I shut the door the the ding dong goes away instantly - so that would tell me the switches are fine. At anyrate the light and the door ajar light stays on for about a minute or so then goes out and all is good. I'm wondering now if anyone knows anything about the door ajar/dome light relay and its location and cost. Any insight would be appreciated...
Old Feb 22, 2002 | 12:29 PM
sdcoppola's Avatar
The same problem with the door ajar light staying on just started happening to me this week. The interior lights stay on for about a minute or more.
If I drive, the interior lights will go out, but the door ajar light stays on. I checked the fuse, I am not sure where I can grease or oil a switch.
Sorry that I cannot help yet, I have the same problem though.
Old Feb 28, 2002 | 01:10 PM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Did you guys use WD-40 sprayed under and inside the doorhandle????. this will work i have fixed many..
Old Feb 28, 2002 | 01:34 PM
sdcoppola's Avatar
I read the other posts which mentioned road salt and humidity as a possible cause. The problem happened after a trip to Vermont and upstate NY. So the truck had salt all over it. After two washings, the problem has stopped. When the weather warms up a little I will try the spray of WD40 for good measure at each door. Thanks
