After market keyless entry
Old Feb 13, 2002 | 11:04 PM
medic's Avatar
Question After market keyless entry
I'm having trouble wiring in an after market remote starter with keyless entry on my '97 F150. The remote stater seems to work fine, but I just can't figure out what wires to hook the keyless entry wires into. I know I need two relays with an alternate power supply, I'm only having trouble figuring out which of the five wires I need to run this system through. (this truck was not originally equiped with keyless entry)
Thanks for any help,
Mike
Old Feb 15, 2002 | 09:53 AM
fourhour's Avatar
Mike, I'm assuming you have power door locks in your truck! The wires (for a 98') are located in the kick panel behind the parking brake. The lock wire is Pink/Yellow and unlock is Pink/Green. You will need to wire seperate relays, sending a negative pulse for each function. If this is'nt enough info try searching this board. This has been discussed thoroughly many times. Good luck. ennis
