fog lights
i've got a 2k2 f-150 extended cab 4.2l v6. i was just given a set of after market fog lights that I would liike to hook up. but I have no instructions. the only thing i received, the lights them selfs, no extra wiring.
I would like to hook them up so I need to have at least my driving lights on, but that I would be able to use them with my head lights, and be able to turn them off at any time.
any help? anybody?
any help? anybody?
Buy a wiring kit with relay
Go to Pep Boys (or similar parts place) and buy a wiring kit that includes wires, a fuse, switch and relay. The fogs can operate independent from your present lights. The wiring will be like this. Hook a fused relay to the positive side of the battery then to the lights. The switch will go to a 12 volt source then to the relay to operate it. Basically, the relay is a switch that is energized by another switch to run high voltage to the lights.
HTH,
Marv
HTH,
Marv
