Need Help Bad
Old Jan 26, 2002 | 03:25 PM
F15042642's Avatar
Question Need Help Bad
I need help I hooked some lights to day ,a wire hit the bumper .now my high beams does not work (I was hooking them into my high beam)low beam work, the high beam light in the dash does not work . what is wrong how do I fix it and where it is at.
Old Jan 27, 2002 | 10:31 AM
Ford4ever's Avatar
Try replacing the bulbs, it may have blown them, you could check the fuses too, but i think the same fuse may be used for the hi and low beams so that might not be the problem. Next time disconnect the battery when you do any electrical work.
-Jon
Old Jan 27, 2002 | 12:13 PM
Chopper's Avatar
Apply the KISS principal.......... Check the High Beam fuse located under the dash on the LHS. Check your owners manual for the location in this panel of the H?B fuse.......:o
Old Jan 28, 2002 | 10:13 AM
F15042642's Avatar
It was a fuse I check before I post .I was looking at the wrong fuse, Thanks you for your help.
ford4ever has your truck ever seen the mud it looks like it would go great.
