General Cheapness...Getting to Me
Old Dec 27, 2001 | 08:32 PM
rockerc's Avatar
Dont get me wrong, I love the truck however things like ill detail below really irk me!
First of all, the **** for the power mirrors doesnt stay on, and eventually, about 2 months ago, fell off and went AWOL on me. Anyone have this happen to them?
Second Rant: The plastic piece on the very end of the gear shift selector (NOT 4x4) breaks off frequently. I found that superglueing it works for about a month, then it breaks off again?
Ok /rantoff
Keep on truckin!
Old Dec 27, 2001 | 08:38 PM
MisterP's Avatar
The plastic surround for my O/D button falls off almost Daily
Old Dec 29, 2001 | 09:27 AM
J-150's Avatar
In both cases, the plastic piesces are probably broken. Replace both and you should have no other problems.
Old Dec 31, 2001 | 07:21 PM
robertm682's Avatar
Thumbs down Cheap Glass, too
Besides the front license plate holder that is hooked on with simple plastic tabs that DO NOT give me a lot of faith my license plate will remain on duty, I find a whole lot of Fords with cracked windshields. Mine took a pebble the size of a pea, and cracked along the top. My 12-year old Ford E-150 also suffered a cracked winshield, and as I drive around, I see a disproportionately high percentage of Ford vehicles (especially F-Series trucks) with broken winshields.
Come on, Ford! Give us a break, but not in the winshield!
Old Jan 1, 2002 | 03:26 AM
levi98's Avatar
Angry
After my '93 f150 I said no more fords. Somehow I wound up buying a used '97 f150. What's the first problem I have? The window washer switch doesn't work! Solution; take the switch apart and remove the factory grease and reassemble with a nice conductive grease. Why do I mention this in a general cheapness thread? Because I had the same problem with my '93! How can ford not correct this type of problem over the course of 4 years and a complete redesign??? I also have the intermittant door switches, missing shift lever cap, and a flaky hot/cold control that seem to plague these trucks. And no limited slip in the rear. That seems the height of cheapness to not make limited slip standard in a 4x4!
other that these few items I really like the truck. Thank God for these forums to assist with all the problems!
Old Jan 1, 2002 | 03:40 AM
Y2K 7700 4x4's Avatar
Ford has a flakey WW switch -- often turning on the wipers and washers by itself when you least expect it.
I've experienced it on both a 95 Ranger and 97 F-150. The dealer feigned ignorance -- but had them in stock (hmmm).
Several others on this board have noticed that their truck came with that "feature".
