HELP -how to wire new pedals
Old Nov 11, 2001 | 08:47 AM
Robb's Avatar
Question HELP -how to wire new pedals
Hello, I just got these glowing pedals, but I dont know how to tie them into the headlamp circuit from underneath the dash at the fusebox. Any HELP is appreciated. Thanks, Robb
Old Nov 11, 2001 | 08:59 AM
Ford4ever's Avatar
You could get some of the pointy terminal ends and plug them into the top od the headlight fuse. This wouldn't look very professional though. You may be better off tapping into the wires that come from the headlight switch. All these wires do is turn on the headight relay so if you tap into them it shouldn't dim your headlights at all.
-Jon
Old Nov 13, 2001 | 07:41 PM
MisterP's Avatar
Ford4ever
I ran the wires up under the dash and behind the ashtray. You can slide the ash tray out and then press on the two tabs that are between the ashtray and dash itself to release the ash tray. There is a single light bulb to light the ashtray which you can tap into. Thats what I did at least.
