Poor Startup
Old Jan 13, 2025 | 12:38 PM
PickupCruzer's Avatar
Poor Startup
2009 5.4 continues to crank after key released. Poor startup began at same time.
Old Jan 13, 2025 | 01:40 PM
​​​​​​​That's normal, it will crank till it starts or times out.
Old Jan 13, 2025 | 03:13 PM
Thanks, but...
I guess it normally popped right off? So, a longer crank, and when it starts it's unstable idle, and will die if I put it in gear too soon. 124k it's never done that. (Or anything but run perfect, til now).
Old Jan 13, 2025 | 04:28 PM
How many miles on the spark plugs? You may need to clean the throttle body.
Hope it's not the fuel filter, it's inside the tank.
Old Jan 14, 2025 | 10:58 AM
Reply to GLC
GLC, (sigh), I knew you were going to say that! The spark plugs are original at 124k miles. I'm scared to death to touch them.
Old Jan 14, 2025 | 12:28 PM
2009 has the redesigned heads, changing spark plugs is no big deal. They won't stick and break.
