Warning lights and no a/c
I am stumped. 2010 F-150 V8 Platinum. Warning lights on are Brake Traction Control and Tire Pressure Monitor Fault, No instrument Lights And the A/C only blows hot air. It has to be a rely somewhere to effect all of these. No codes found in a scan. Now with all that said I moved around fuses under the hood and now it works like it should. Which fuse could it be that controls all this. I am stumped. Thanks all I did do a search but could find nothing like this. Fuse breaker relay what gives.
You need to be specific. There are many "OBDII scanner" devices that do not have the needed capability for reading the auxiliary sub-systems.
You are correct the scanner I have will only read basic codes I have found out. Any ideas how much Ford might charge to do a in depth scan? Or would that even help since it seems to be intermitting. Thanks
If you have a Windows laptop, try Forscan. You need a compatible adapter ($35), and you may need an extended license, which is free for 2 months then $12 a year.
https://forscan.org/home.html
Adapter:
Adapter:
