Reverse lights not working for a 01 ford f150
Old Feb 18, 2022 | 12:50 PM
tonytiger45's Avatar
Hi wondering if anyone knows where the reverse lights are grounded on the XL model it has the 4.2 and a manual transmission.
Old Feb 18, 2022 | 01:40 PM
projectSHO89's Avatar
G104. Left front radiator support, regardless of trim level or transmission.
Old Feb 18, 2022 | 01:59 PM
Ah ha now i know my issue right away😂😂 I almost have no lower rad support left this truck was an upstate NY truck previously, but an easy fix for the ground i will reground the reverse lights somewhere in the rear of the truck using the factory ground wire I have power at fuse #5 for the tow wiring I first had to replace the fuse it was blown so I knew after that I am missing ground for the connector to the socket, but thanks for your info.
