Need all the help I can get
Old Sep 3, 2021 | 06:18 PM
Kmbf150's Avatar
I have a 1997 ford f150 4.2 v6 automatic transmission 2 wheel drive 8 ft bed single cab with 155000 miles on it. I've experienced my truck shuts off while driving. First my headlights,stereo and gauges to down, then the truck beeps a few times then shuts off and wont restart. The beep sounds like it's coming from passenger side of the dash. So far I've done oil change, changed fuel filter,replaced 02 sensors, new air filter, new coil pack,new spark plugs and wires, new idle air controle valve, new battery,new altenator and new belt.
Old Sep 3, 2021 | 06:31 PM
Roadie's Avatar
After shutting off, does the starter spin the engine as fast as it usually does?
Old Sep 3, 2021 | 06:34 PM
Check ALL of your grounds. It might be a grounding issue.
That also includes checking the fuse boxes for underlying corrosion.
Good luck...
Old Sep 10, 2021 | 09:07 PM
5spd's Avatar
Could be a windshield leak
Old Dec 5, 2021 | 07:43 AM
jackyjoy123's Avatar
Good luck...
thanks for the awesome information.
Old Dec 5, 2021 | 10:50 AM
serotta's Avatar
Years ago I had similar issues with my old 97. the windshield leaking on the driver's side was the culprit. There are vital electrical components under that side of the windshield.
