Need some FORD Tech help
Old Jun 26, 2020 | 10:19 AM
Fbird's Avatar
Hello all, working with an '02 Windstar. I am adding a "mirror cam with back-up cam". My question is since the REAR lights are controlled/powered from the rear GEM MODULE, how many amps will said module support? I do know in the past trying to add a trailer plug required a separate power run all the way to the battery. Given the ONLY change would be tapping the REVERSE LIGHT circuit to light a few small LED's as the 12v triggers the camera system. I expect i only need about 2 AMPS to run this but would still be note worthy to know WHAT the GEM will support.
