Passenger and rear window buttons not working
2002 F150 Supercrew passenger and rear windows buttons do not work. The drivers door controls for all windows work fine. I can raise and lower all windows from the drivers door controls but the buttons on each door (passenger and both rear doors) do not work. This happens both when the window lock button on the drivers door is on or off. Therefore, could this be a bad window lock button?
I know, you should never just throw parts at a problem without diagnosing it. I just happened to be luck enough that my brother had a similar truck with the same window switch. He was tearing the door panel out search for leak. i borrowed his switch panel and it solved the problem so I bought one.
