Fuel cut off while acceleration please help
Old Feb 12, 2020 | 02:25 PM
Abas Usah's Avatar
Unhappy Fuel cut off while acceleration please help
Hello , so my fuel cuts off while I accelerate
Please what is the problem and how can I fix this
Model ;f150 2004
5.4l
Old Feb 12, 2020 | 02:35 PM
Abas Usah's Avatar
Unhappy Which relay controls fuel pump on the fuse panel in 2004 f150?
Which relay/fuse controls fuel pump on the fuse panel in ford 2004 f150
5.4
Old Feb 12, 2020 | 03:04 PM
Fuse and relay chart is in the owner's manual. If you don't have one you can download it.
https://owner.ford.com/tools/account...r-manuals.html
However, you need to inspect the FPDM for corrosion, that's a common cause of fuel pressure issues. It's located on the crossmember above the spare tire.
If the fuel filter has more than 30k miles on it, change it.
Old Feb 12, 2020 | 03:18 PM
Abas Usah's Avatar
Thanks so much
