2002 F150 headlights not working.
Old Aug 21, 2019 | 02:30 PM
Eric Dollar's Avatar
Hello, I have a 2002 F150 and the headlights recently stopped working. If I pull the FTP lever for brights, they work. But other than that I have no DRL'S or headlights. I've checked both fuse panels and they're good. Any help would be greatly appreciated!#
Old Aug 21, 2019 | 03:46 PM
projectSHO89's Avatar
There are no fuses that can cause your set of symptoms as described.
Are you POSITIVE the DRLs are not working? (Main light switch not in the "Headlight" position and ignition in RUN = low beams at reduced output)
