Help with P0443 DTC
Old Mar 31, 2019 | 12:15 PM
DerrickDude's Avatar
Help with P0443 DTC
Hello Everyone!
I have a '97 F-150 XLT, 4.2L with standard trans. I have been troubleshooting a P0443 DTC on my truck and have hit a road block that maybe someone can help with or at least point me in the right direction.
Here is what I have done so far:
1. Replaced selenoid at firewall - still pops code!
2. Key on voltage check at plug - 11.98 volts - within limits!
3. Ohm checked new selenoid - 35 Ohms- within limits!
4. Key off voltage check - 0.270 volts - SHOULD BE 0??????
That is where I am stumped - there should be no voltage with key off. My question is this - is that quarter volt enough to trigger the DTC? If so, can someone please tell my next step as I am completely stumped on this?
Any suggestions would be greatly appreciated! Thank you in advance!!!!
Old Mar 31, 2019 | 01:05 PM
This might help:
https://www.obd-codes.com/p0443
I'd start looking at wiring issues - loose, corroded, broken, etc.
Old Apr 1, 2019 | 12:39 PM
Originally Posted by glc
This might help:
Thanks for that link. I did check all the wires back to the ECM, everything looks good. I am starting to think that the ECM is going bad and will probably need to be replaced.
God I hate troubleshooting electrical!!!!
Old May 17, 2019 | 06:22 PM
Sorry y'all, I meant to follow up on this a couple of weeks ago.
It turns out the ECM was indeed bad. It had a bad ground circuit that failed to trigger the solenoid valve. My first clue should have been the voltage reading with the key off. I replaced the ECM and it is now error free. Thanks for the help. Hoping for another 280,000 miles out of this old girl!!!
Old May 17, 2019 | 07:45 PM
Good to hear with the 280K.
I haven't been driving my truck much... only because eh... haven't felt like it. For the past 3 years its been a sincere garage queen.
