Rear sliding window
Old Sep 12, 2017 | 02:05 PM
panzerstg44's Avatar
Rear sliding window
Can anyone please tell me what fuses/relays supply power to the overhead switch on a 2006 lincoln lt?? I finally got to the switch and can't find any voltage and I have no manual but the cover gives fuse locations ANY help would be great.... THANKS Dallas
Old Sep 12, 2017 | 02:30 PM
Download the manual.
http://www.fordservicecontent.com/Fo.../06mltog1e.pdf
Old Sep 14, 2017 | 04:45 PM
Hi glc, You seem to be the one that always comes to my aid and I thank You kindly for all your help !! I downloaded the pdf of the fuses and checked all that were anywhere near the back glass and all were ok I then finally got the overhead part with the map lights and the slider switch down and I checked the red and black wires and found no current and I know I checked all the fuses more than once. I thought of running a jumper wire with 12 volts to the red side and see if it would work but I was afraid I would fry something and my son in law said he didn't think that was a very good ideal either, can you think of anything else I could try..THANKS ------Dallas
