Alternator Question
Old Sep 9, 2001 | 05:02 PM
awhittle's Avatar
Alternator Question
I am building a trick battery charger from an old electric motor and an old auto alternator. On a typical alternator (external regulated) there are 3 wires plus a ground. 12v positive that goes to the battery, Field that gets the input voltage (4-12 volts) that the voltage regulaters uses to charge the field, plus another termal that is normaly there. What does this last termal do?
Andy
Old Sep 14, 2001 | 11:40 PM
InfernalCombustion's Avatar
Im just guessing here, but the third wire may be the return (or common or ground) for the voltage regulator signal. Having a seprarate return for the regulator signal would allow the regulator to keep a more constant signal to the field, regardles of the the current fluxuations on the armature.
