Adding auto roll down to passenger side
Old Apr 8, 2015 | 09:35 PM
Diesel5897's Avatar
Hey guys new to the forum.
I have searched but have come up empty on any threads that state what the process would be for adding auto down to my passenger side window and on the Drivers side panel. I have a 2010 Lariat but it only has auto down for the driver and I have seen the master window switch with both but not sure how I would accomplish this. I am assuming splicing wires together would be involved but wondering if there is a kit out there or if anyone has done this with a step by step to simplify it for me.
Any suggestions would be greatly appreciated.
PS. Coming from a Jeep so still trying to learn everything on the truck so forgive the inexperience in advance.
Old Apr 10, 2015 | 01:06 AM
Steve83's Avatar
I'm not 100% sure, but I think those windows are controlled by the SJB (Smart Junction Box) which is essentially a fuse/relay block with some built-in logic; including some that keeps the driver's window down relay triggered after you release the button. I don't think there's a kit to make any other windows behave that way, and it would probably take a substantial amount of rewiring to bypass the SJB and make the windows work the way they did in older trucks...so that you could THEN add an older 1-touch module to the windows & directions (1 for down; 1 for up) that you want to be automatic. On my Bronco, it was fairly straightforward:
Old Apr 10, 2015 | 08:29 AM
SSCULLY's Avatar
Good news, the 2010 did not have any serious changes to it yet.
One touch down is via the solid state control in the master switch, the other windows are "old school" switches same as the 2001 ( maybe older ).
This means you can add a OTD module to the window.
I installed the kit that Pony Performance sells.
http://ww.ponyperformance.com/specials2.html
- The 2004-2008 kit is the one I used.
Steve had a CV thread on the Pony Performance modules.
- maybe a quick search of his SN and pony performance would turn it up ???
Old Jul 7, 2015 | 11:03 PM
Diesel5897's Avatar
Thanks SSCULLY. Ill take a look at the link.
