Ignition Issue Help
Old Mar 24, 2015 | 03:51 PM
jdurso's Avatar
Ignition Issue Help
Went to start my truck this morning and when I turned the key to the start position it did not spring back to the run position and I had to do so manually. The switch has stuck before and worked itself out but that doesn't appear to be happening this time. Anybody have some insight on the cause of this problem? How hard/costly is the fix?
