Dome lights 2005 F-150
Old May 13, 2014 | 10:04 PM
Tommy Johnson's Avatar
Dome lights stay on for 20 mins. I've strayed the door locks with WD-40.
It just came back from the dealer for a throttle body cleaning. While it was in they did a Reprogrammed PCM. The dimmer switch is in the off position.
Question 1 Could this change the setting on the dome lights?
Question 2 What relay should I check and its number at the fuse panel?
Question 3 What number are the fuses to pull out to turn the dome lights off?
