2013 Camera Replacement
Old Apr 17, 2014 | 07:08 PM
Sbradenadams's Avatar
This is for anyone thats interested in the OEM camera on the 2013 and probably 2011-2012 F150s.
I just recently had mine replaced under warranty. 90% of the time, if your having issues with your camera, its NOT a harness issue. The camera has a software module built in, which often presents issues. When symptoms arise such as "Camera is unavailabe", or lines showing across your screen, You most likely need a replacement camera, and in turn, a replacement emblem. It seems as if Ford updated these cameras after the 2013s rolled out.
If your camera is blurry off and on, chances are that you will likely see these issues down the road, something tells me the V1 camera on 2013s wasnt so great.
