'07 F-150 XL "Black-Odometer"
My odometer lighting is no longer functioning, although the odometer, itself, is working fine. The lighting worked, intermittently, for a brief period, but has now stopped functioning, altogether. Is this the "solder-joint-issue?" How difficult is the repair?
Thanks in advance.
Thanks in advance.
Few threads on this topic
https://www.f150online.com/forums/20...placement.html
https://www.f150online.com/forums/ar...ht-repair.html
If you are in the group that your Ford service writer told you they had to replace the whole cluster, don't feel alone, a lot of members got the same info from the know nothings at the dealer.
If you need some other threads search on odometer bulb or odometer backlight
