2002 screw power window problem
Old Nov 13, 2013 | 08:01 PM
EVIL_SVT's Avatar
Just to be clear both my new switch and my original switch had the exact same broken solder. I used my old one to use for test purposes just because it was easy and already out of the truck. When I soldered it and tested it to make sure it worked I then took apart the new one and did the fix on that one also. I now have a spare switch which is cool but it cost me over $150.00 for the new switch and switch cover (part that connects to armrest) because the original one broke from pulling it on and off so many times.
I would assume this is a common problem but then again I have only heard one other person complain about it and he never posted his results. Or I just have the horrible luck of being "that" guy who just gets the bad ones from the factory lol...
Old Nov 17, 2013 | 09:14 AM
SSCULLY's Avatar
thank you for closing out the thread with what you found wrong.
the next member searching for this issue will appreciate it.
Old Nov 19, 2015 | 07:42 PM
Number 7's Avatar
2002 4x4 XCab f150. Window won't roll up. Relay was clicking, changed it anyway and changed the motor today. Relay clicking, nothing happening with window. Anyone experienced this issue? Thanks for help.
