2000 f150 V6 starter issues
Old Nov 2, 2013 | 03:04 AM
Michealdrc's Avatar
My 2000 f150 V6 has just aout 400,000 kms on it and it has let me down for the first time!
My truck will not start.
I put the key in the ignition, turn it and all the guages swing back and forth, then settle with the chimes going and all warning lights illuminated.
I have a strong battery and good clean connections.
I'm thinking ignition switch?
Thanks in advance
Mike
Old Nov 2, 2013 | 08:36 AM
projectSHO89's Avatar
More likely a bad battery cable or connection. You need to get out a meter and test them, not guess.
Old Nov 2, 2013 | 08:52 AM
nonwoven29's Avatar
Like project said. You need to use your multimeter. Do a drop test across the battery Check potential, Then continuity test.
Old Nov 2, 2013 | 11:21 AM
Michealdrc's Avatar
Old Nov 2, 2013 | 01:23 PM
Michealdrc's Avatar
Thanks for your help. I put a meter on battery 12.4 volts connections good I even get same voltage at starter and starter relay.
The guages still swing back and forth once when I initially turn the key, the attery light does stay on. No clicking or any noise from starter.
Mike
Old Nov 2, 2013 | 07:38 PM
Google 'Voltage drop test'
You have to test them under load.
Old Nov 3, 2013 | 11:34 AM
Michealdrc's Avatar
Will do. I just have to say I am not a mechanic ut I generally am ale to muttle my way through. Thanks for your help.
