battery light issue
Old Oct 24, 2013 | 12:52 PM
maxwell_smart00's Avatar
battery light issue
I have developed a battery light on my dash this morning.
It is showing full charge in the battery at the moment, but the light appeared on my drive to work.
It was not there in idle, but appeared when I started driving normally. If I rev the engine, the light goes away temporarily.
Is this a battery issue, or an alternator issue?
Actually, now that I've driven it a bit, the charge is showing just below half..
Old Oct 24, 2013 | 12:55 PM
battery light
battery light is on - disappears when I gun the engine...
Is this the battery, or the alternator that's at fault?
Old Oct 24, 2013 | 12:57 PM
Alternator 100% on its way out.
The battery light is actually not for the battery. Its shows lower than expected voltage is present, indicating low or no charge from alternator.
The battery will maintain voltage for a short while, that's why the voltage guage didn't drop much if any.
Old Oct 24, 2013 | 01:03 PM
Threads merged, one thread per subject please
Old Oct 24, 2013 | 01:24 PM
thank you.
How hard is it to change? Looks like a belt tensioner to release, a few bolts, and not much else...but it's -3 already, and I don't have a garage...
Andrew
Old Oct 24, 2013 | 05:56 PM
Yah there's a little brace that runs across the bottom, but its very straight forward on the top of the engine
Old Oct 24, 2013 | 06:19 PM
Just swapped it out - not bad at all...had to take off the antifreeze hose, so it was a bit messy - but not bad otherwise!
