Window/lock issue
Old Sep 4, 2013 | 11:04 AM
Vaultdweller's Avatar
Window/lock issue
Got my truck, and now I have an electrical issue, not sure what to do. The power locks do not work at all, using the switch on the passenger or driver side. Also, the driver window woes not work......however, the passenger window works using the switch on either side. When you use the switches for the locks and driver window, I hear a clicking sound, like the power is trying to get through somewhere. The sounds seems to be coming from forward and center of the cab.
What should I be looking at as the source for the problem? Looking fir a general idea before I start working on it.
Old Sep 4, 2013 | 07:05 PM
SSCULLY's Avatar
I would take a SWAG that you have 2 problems.
1. Window.
Some MY have an issue where the power window motor "hangs up" and stops working.
Here is a thread on the diagnoses steps for that symptom.
https://www.f150online.com/forums/el...dow-motor.html
2. Power Locks.
Did you check the fuse for them ?
- Also if you can note if you have the RKE ( remote Keyless Entry ) feature on the truck.
