Hi! Having problems w/ charging, gauges. Alternator or ?
Old Jul 20, 2013 | 02:29 PM
Stan Williams's Avatar
Unhappy Hi! Having problems w/ charging, gauges. Alternator or ?
Hello. I drive a 2000 F-150 4 x 4, V-6, EFI, A/C, ABS. Yesterday while driving on the interstate w/ my headlights on, my dash gauges and radio quit. When I turned off the lights, they all returned immediately except the alternator which was flat. Then, w/o any changes, it sprang into service, charged the battery enough in abt 15 miles for a restart 30 minutes later, but almost immediately upon returning home, it charged for a few minutes then slowly went flat (0) again. By the time I'd traveled abt 20 miles, the truck died but was easily jump started and fortunately I made it home but the battery is too dead now to turn over the starter. It seems that once I get the engine started. the alternator works until the battery is charged then shuts itself off or it may only work for a specific period of time. FTR, the battery is new and under warranty, the alternator is the original. My question: is this a simple alternator problem or could there be more complex (computer, fuses, etc problems or both or ?? And can I diagnose these w/o an expensive machine?
Old Jul 20, 2013 | 07:19 PM
Stormsearch's Avatar
25 Year Member
About the only thing you could check is the voltage at the alternator B+ stud. This will ensure there is no short or open circuit in the b+ wiring between the alternator and battery. Beyond that you've done more than most folks and if the above doesn't show anything, time to replace the alternator. A 13 year old unit did fairly well. Don't let it go too long or it may end up killing your new battery if not already limiting it's peak capacity.
Old Jul 20, 2013 | 07:58 PM
Thanks, Stormsearch.
