Horn Trouble
Old Jun 8, 2013 | 07:22 PM
Cowhead2's Avatar
Angry Horn Trouble
Horn went off continually on sons truck. Battery cable was loose tightened that and horn stopped blowing but fuse blew . After that whenever I put in a new fuse and hit the horn it would blow so I have replaced horn and fuse, horn still doesn't work. Now when horn is pushed I can hear a click at the relay but that's it. I swapped in a known good relay and still the same thing. Any suggestions?
1997 F150 V6 5 speed manual
Old Jun 9, 2013 | 10:14 AM
SSCULLY's Avatar
I would start with Check to see if the ground is being applied to the relay for the horn
- confirm the click is the relay contacts being activated by the coil
If you pull the horn relay, inside the socket you should get + VDC at pin #2
Picture of relay ( check that you are using the socket view not bottom of relay view )
Quick 1st test, meter on pins #1 & #2, see if you have + VDC without pressing the horn ( test if switch is stuck ).
If not, same meter test for + VDC, press horn, should have + VDC on meter, if not need to figure out if + VDC is not on pin #1 ( use another known good ground to test pin #1 ).
If this test good, time to bench test the relay.
apply + VDC to pin #1, ground to pin #2 and check for resistance over pin 33 & #5. Should be < 100 ohms resistance.
