key on hot wire with easy access?
Old Jun 7, 2013 | 02:37 PM
rojizostang's Avatar
i purchased a 2013 stx regular cab and i want to install an amp. i need to find an easily accessible key on hot wire to control it. anyone know an easy place to access one?
Old Jun 9, 2013 | 09:53 AM
SSCULLY's Avatar
The only ones that I can find that are:
Hot in Run or Start are :
BCM Fuse # 36, 37, 41, 42
Hot in Run / Accy :
BCM fuse # 43 & 44
- These are marked as unused, so you need to check that the fuse supply slot has + VDC in run / accy positions.
Any of these just use an ATM Add-A-Fuse in the slot to get the new circuit for turnign the AMP on / off ( these are max 10A on the added circuit ).
Old Jun 12, 2013 | 09:20 AM
i wound up using #38 in the sjb. i used a mini add a fuse and tapped in there. it's the accessory delay fuse, so the woofer runs just like the regular radio does. it keeps working when the motor is off and then will cut off when you open the doors are the timer runs out.
Old Jun 13, 2013 | 09:58 AM
SSCULLY's Avatar
Thank you for point that out, I completely missed those fuses when searching cell 13 in the EVTM. I saw the hot at all times and moved on, not paying attention to the fuse after the micro controlled relay for the accy delay.
Thanks again
