2006 f150 power seats
Old Jun 6, 2013 | 01:30 AM
allpinball's Avatar
2006 4-door
drivers seat acts like it has no power.
checked the green&black connector below seat - reads 12v...until you energize any motion switch, then it goes to zero. let off the switch, back to 12.
I jumpered 12v from the cig liter to the green wire and seat works fine.
Must have a break in the wire or a bad connector somewhere.
F109 is good and the adjustable pedals work fine.
this diagram sows the DG wire from the fuse box to the seat. can someone describe where connection points C270M, C3134 and C369 are?
https://www.f150online.com/forums/me...ower-seats.jpg
Any known common points of failure for that circuit/wire?
Old Jun 9, 2013 | 09:38 AM
SSCULLY's Avatar
C270M : Shows as on the side of the Cab fuse panel.
C3134 : Should would be a connector under the seat ( i.e. wire is from under the carpet up to the connector and then fans out to the items on the seat ).
C369 : Shows as on the back of the switch itself on the side fo the seat.
Do you have power seats or power seats with memory ?
- 2 different diagrams, just want to verify which you have for what you should be looking at.
What wire did you check in the connector under the seat ?
When you jumpered +VDC to the Green wire, are you talking about the Dark Green Wire ?
