12v Junction/Fuse Box
The battery to the alternator is fused with fusible links.
Nothing should every be left to create an unprotected / high resistance short to ground.
Don't know what you have for additional items. If the inline fuse, for a given item is correctly sized, it should be a direct replacement.
- Dangerous game to play with current draw.
Look at 14/3 SO cord and 12/3 SJOOW cord next to each other.
They look the same from the outside, even using calipers. Does not make them the same.
Your truck, you can do what you want to with it, 105* automotive 6 AWG is good for no more than 70A in short lengths. If you go with 6 AWG 90* THHN wire from Home Depot, it will be lower.
- Over sizing a fuse is just as dangerous as not fusing a circuit.
I used to go on the low end of the rating. I'd rather have it blow. I've always go on the limb and go with a 15 amp fuse, and if it blows 3 consecutive times, and there is nothing wrong, then I'll ramp it up another 5 amps.
But since then I do the math and use my amp-meter, and from that I will know exactly what the current draw is.
- My 2006 MY F150 does not.
From the battery to the CJB through the firewall.
That is the main feed to the CJB.
It is still guessing that it is not larger than 4 AWG, using the drive by look at the wire.
- Can't visually confirm what AWG wire is.
i'll throw in my 2 cent - and i'm a licensed master electrician
first - wire construction - insulation thickness changes based on use
and wire gauge is based on ability to handle heat, that said - 4 ga wire has a higher amp rating then 12 ga.(i'm sure you knew this already)
second - types of wire - automotive wire is made up of more strands, this allows them to handle vibration better and insulation due to higher eng. compartment temps. commercial/house wiring uses thicker strands and is very stiff and insulation is commonly rated at only 90*c ( it's allot hotter
under the hood on a summer day)
manufactures use cost controls which means bare minimium. wires sized for the max load with time limits so it's ok if it heats up a little.
if you are adding curciuts, wire and protect them with propperly sized wire and fuses this will help in propper operation and IF something does happen to go wrong your insurance would be less likely to deny claim.
as a vol. firefighter (20+ yrs) i've seen plenty of eng. compartment fires started by wiring and always the same "i just had that installed" which means they did it them selves.
so yes- use larger then 4ga and fuse the battery leed at 100 amp and use automotive wire. crimp connections if possible or use a good mechanical connector, use corrosion protection on finished items.
