2000 F150 drivers window wont roll down-or up
Hey Im here to try and fix the issue myself before taking it to a shop and dishing out more money then needed..
So far to try and fix the issue I have checked all fuses with a power tester and replaced the relay inside the cab.
I took a video to show what happens when I give it a try.
The last 6 months to a year it has been working intermittently, but maybe 2 months ago it just stopped working and hasnt moved since then.
Its been way too long without my window working so I need to get this fixed!
Any ideas?
I had a guy today tell me its probably the master switch that went bad, but when I look online they come in sets so how could the left be out but not the right?
http://www.ebay.com/itm/NEW-1999-200...14acbb&vxp=mtr
or would he have been talking about the electrical components that connect to the switch?
anyways heres the vid so hopefully someone has ran into the same problem and solved it without having to take it in!
Im pretty handy when it comes to tasks like this so if I need to solder a connection or rip open the door panel it wont be too much of a challenge.
CLICK
Thanks!
Any ideas?
CLICKThanks!
https://www.f150online.com/forums/ar...ow-switch.html
It could be also the window motor too.....dorman makes a good replacement
gave that a try but it didnt help. However now I have very clean switches!
is there any way I could test JUST the motor to see if its working or not? (IE short the connection to see if the motor spins or not)
I'm having the same problem with my passenger window, if u take ur door panel off an unplug the motor, get some sort of 12v power source an stick positive in one of the holes an the negative in the other your motor will work it its still good, on way is up an if u switch it the other way will be down...
I checked all my fuses, my switches an my motor an still can't seem.to solve the problem. Hope this helps
