Larriet - Changed battery now the stereo doesn't work!
Old Aug 16, 2012 | 02:38 PM
Shoa Chi's Avatar
I changed the battery on my Larriet 2006. Everything works great except for the stereo. I have looked at fueses 1, 7 and 22. These are the ones that I saw relating to the stereo, but none of these are blown.
Please help me understand why the stereo/sirius satallite quick working!! Like I said, everything else is working but the stereo.
When I changed the battery I cleaned the terminals and put a protective spray on it!
Thank you in advance for the help!
Samantha
Old Aug 16, 2012 | 02:57 PM
Takeda's Avatar
It looses the station pre-sets when the battery is disconnected. Try programming your station pre-sets and it should work ok.
Old Aug 16, 2012 | 08:16 PM
SSCULLY's Avatar
I take it stereo doesn't work means dead ?
Is this a factory system ( did not upgrade the Head unit ) ?
Dumb question, you did push the vol button to turn it on ( after power loss, it will reset to off, same as the HVAC panel ).
How did you check the fuses ?
1. Pull and stare at them, and put them back in
or
2. Use a meter to a known good ground and check for + VDC on each pin on the back of the fuse ?
The fuses for the radio would be 1, 7, 22, and 31. 38 is the sub ( if equip'd )
F1 and F22 the key needs to be in the accy or run position to check, 7 is only hot in the start position.
