wire harness
Hi. If I have a shorted out wire going to the instrument cluster will I have to replace the whole harness or can I just replace one wire. Also, does anyone know the cost of the harness. I am thinking it isn't cheap. I have a 2006 Ford F150. 44700 miles. Thanks alot!
You will be pain and money ahead to replace the single wire vs. trying to install a complete harness.
just be sure of the 2 ends of the wire that you are replacing. |
"have to" is a relative term. To fix the cluster's operation, replace any frayed, worn, seperated or naked wires. To fix the issue the RIGHT way, replace the harness. I price a rear ABS harness the other day for a customer and it was 4 wires...$120. Would it be worth it to buy the harness? No. If it is just one wire with an issue, solder a new wire in there, heat-shrink it and plug it in the correct hole with the correct pin/connector and you are good. I am sure your cluster harness would be ridiculously pricy
Thanks alot guys. I was just worried because I was talking to someone the other day that said they paid 900 dollars for a wire harness. Not sure which harness he had to buy, though.
If you have a shorted wire, my question is why is it "shorted". Is it cut? Does it have voltage on one side? If not, have you smoked a fuse or worse a control unit? Wires that just "short" are very uncommon anymore. And most of the time, just because they are cut, nicked, etc. doesn't mean that something down the line hasn't caught the brunt of it and replacing one wire will alone fix it.
My windshield leaked alot right around the fuse box and the wiring. Water would come in good on the passengers side when it rained hard. Just checked recently and see it is still leaking a little. I felt underneath the insulation and it is wet after raining today. I was told it may be the fusebox itself, but I am just getting some more advice before I take it in.
my gen had this issue, and teh GEM's would go out.
What are the GEM'S? I don't know too much about this kind of stuff. Thanks.
General Electric Module. controls electrical parts on the interior of a truck. Yours being an 06 im not sure if they had that issue, but if you are getting water inside...
I have heard that there weren't any issues with the 06's as far as having the windshield leaking. I am thinking maybe it had the windshield replaced at some point. On the top of the drivers side windshield, the rubber or whatever it is on top of the windshield had to be sealed down because it was coming off and then the winshield leaked on the other side. Sounds like it might be an expensive problem. I was thinking about trading it in before this happened. I hope they don't offer me a ton less if I end up trading it in.
Originally Posted by beagles99
(Post 4874490)
