Intermittent "click" no crank
Old Jul 17, 2012 | 02:38 PM
Takeda's Avatar
Yesterday my '05 5.4L developed an intermittent "click" and no crank problem. After trying to start 6 or 7 times, it finally cranked and started. This morning the "click" no crank problem was back. In doing some voltage measurements while my wife turned the key to the start position, I found that both solenoid terminals had 12V. I then measured the wire going into the starter and it only had 300mV. I then disconnected the negative battery terminal, and removed the wire connector from the starter solenoid going into the starter. The solenoid terminal nut was not tight, and I could see arcing burns on the bottom side of the connector. I then cleaned the cable terminal, and the solenoid terminal with a wire brush, and tighten the nut. Problem fixed, no parts needed.
Old Jul 17, 2012 | 02:53 PM
dewalt17's Avatar
Nice find that you were able to fix yourself. I will have to remember this if I ever have such an issue.
Old Jul 17, 2012 | 03:06 PM
Takeda's Avatar
Thanks!
Old Jul 17, 2012 | 03:11 PM
Glad ya found it.....interesting that it was loose though....
Old Jul 17, 2012 | 03:15 PM
Takeda's Avatar
Thanks! Yes, only the starter side terminal was loose. The battery side was tight, and the coil terminal were tight.
