complete loss of power need help!
Old Jun 7, 2012 | 10:46 PM
jlf99f150's Avatar
Ok I've got a 99 model with a 4.2. i went to start it and as soon as I turned the key I heard a click and then nothing. I lost all power no lights or anything. I disconnected the battery to reset the computer and the same thing happened. I'm thinking that something is grounding out or maybe the solenoid. I was wondering if anyone has had this issue before or had any suggestions. I have to get the truck back running ASAP as it is my DD so anything and everything is appreciated.
Old Jun 7, 2012 | 11:09 PM
do the gauges sweep when you go to key on?
sounds like it might just be a weak/dead battery
Old Jun 8, 2012 | 12:08 AM
jlf99f150's Avatar
Yes the gauges sweep. I know a battery can randomly go dead at pretty much anytime but this battery isn't 2 months old and it hasn't had an issue turning over or bogging down when I tried cranking it earlier today. I did notice earlier in the day when I'd try to crank it that it would have a skip or a miss in it then I'd have to reset the radio and clock like the battery had died. I thought a loose terminal so i checked it when I got home and everything was clean and tight as can be.
Old Jun 8, 2012 | 09:24 AM
the sweeping gauges is an indication of interrupted or low voltage.
you might have a parasitic draw on your hands, possibly a starter issue, but i'd look at the battery and battery drain issue first
