Door Ajar issue
Old Mar 3, 2012 | 04:45 PM
Todd732's Avatar
Door Ajar issue
Left rear door ajar light is staying on and the door is closed. I have a 2009 Supercab. I even pulled off the negative battery cable to see if it would reset and no luck. Does anyone know the fix? Thanks in advance!
Old Mar 3, 2012 | 05:58 PM
BL4CK3D0UT's Avatar
The door trigger in the truck is a -NC circuit. Could be a cut door trigger wire or a bad trigger switch.
FYI: Your door trigger wire is green/purple and is located in the driver kick or SJB, gray 26 pin plug (C), pin 14
Old Mar 3, 2012 | 06:19 PM
Todd732's Avatar
Great info. Thank you! What is SJB? I did some car audio install today. Only thing I cut was the speaker wires. Nothing was touched near the driver kick panel but I did pull off the long rocker panel. May have pinched the wire snapping it back in. I'll take a look.
Old Mar 3, 2012 | 06:23 PM
BL4CK3D0UT's Avatar
SJB (Smart Junction Box) is in the passenger kick.
Old Mar 3, 2012 | 06:45 PM
Todd732's Avatar
I did have the passenger kick panel apart. I will check there too. Thanks again. Much appreciated
Old Mar 3, 2012 | 08:38 PM
canadianelbow's Avatar
The switch for the door is embedded in the lower latch assembly. It will be the only thing plugged into the latch on the rear sc doors. A half turn and pull removes them. Assuming you did nothing to the wiring, the switch is an easy and cheap change out. You could even unplug and run a jumper wire in the connector to test before buying a new switch.
Old Mar 3, 2012 | 08:55 PM
Todd732's Avatar
I found the problem. I accidentally cut the wire under the rocker panel. I was running some speaker wire under there and as I was cutting the electrical tape from the factory to bury the wire, I must have cut it then. Im a dumb ***! lol
Problem is fixed. Thank goodness it was only a cut wire. Free repairs are the best kind!
