ac, fan, control power
have 2001 f150....ac selector, defrost and blower motor stopped working...fooled with 40 amp fuse and got it back on..drove for one day then everything went out...40 amp fuse is good...does power go thru a relay before it gets to dash board controls?
the 40A fuse is for the blower motor only. This goes to the blower motor relay.
Fuse # 105 ( 40A ) -> Black w/ Light green stripe wire -> blower motor relay -> Brown w/ Yellow Stripe wire -> blower motor.
did you check the blower motor resistor ?
- Quick test does it not seem to work in low, med-lo med-hi but on high works all the time ?
