Mystery Connector
Old Jul 25, 2001 | 01:27 PM
Keith Maxwell's Avatar
Mystery Connector
What is the empty connector just below the fuse box on the dash?
Also, is there an easy way to hook up a keyless entry system?
Old Jul 25, 2001 | 08:09 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Welcome to f150online!! Keith.
I've often wondered the same thing,lets see what the guys come up with,,,,98
Old Jul 26, 2001 | 10:47 AM
fourhour's Avatar
I recall seeing that connector under the dash. I always assumed it was for a courtesy light that may have been removed by the previous owner. (The aftermarket remote start was removed but they left the relays for the doorlocks!) ennis
Old Jul 26, 2001 | 11:12 AM
mattadams's Avatar
that connector goes to the electronic brake controller, when you equip it. That should have been included with the vehicle (its just a connector with about 4 wires coming out of it that you hook into your electronic brake controller if you choose ot purchase one.
Old Jul 26, 2001 | 02:10 PM
I thought the brake controller plug was the one by the Gas Pedal.
This one is directly under the fuse box.
Old Jul 26, 2001 | 04:33 PM
mattadams's Avatar
the plug by the gas pedal (if you mean the one that is attached to the dash, that looks kind of like a computer connector with about 20 wires going into it) is the computer diagnostics connector.
Old Jul 26, 2001 | 04:46 PM
No there is one behind that.
Old Jul 26, 2001 | 05:08 PM
mattadams's Avatar
hmmm I don't know what that is for, I'll have to check it out when I get home. I know of one connector that was there that went ot the alarm system or something like that> I'll have to check it out
Old Jul 31, 2001 | 03:47 PM
bluemesa159's Avatar
Question electric brake controller
The electionic brake controller... do y'all mean the box you can install to run the brakes on a camper trailer? I've got to install one that was removed from my old explorer and I have NO idea which wires to connect it to. The directions say something (...haven't looked at it in a while...) about cutting into the brake wire - there are 3 or 4 back there and I didn't know which one!!!
If anyone has any help, I sure would appreciate it!!!
Thanks,
Pete
Old Aug 2, 2001 | 10:28 PM
F150Sven's Avatar
Cool
bluemesa,
Yes, there is a connector built into the wiring for the brake controller so you don't have to hack up the wiring.
Does your truck have the trailer package? You should have a factory receiver hitch with a 7-pin connector. It should have also came with a package containing a pigtail connector, some relays, an adapter to a 4-pin connector, and instructions. If you bought the truck used, it may not be there. I would guess you could buy the package from Ford.
Sven
Old Aug 7, 2001 | 08:30 AM
brake controller
I bought the truck used and put the Class III towing package on myself. Already spliced the 7-pin into the existing 4-pin but obviously I have a couple extra wires to attach.
My next hurdle is the controller inside the cab... when I get back from vacation I'm going to have to figure out where to put it - hopefully I can find this adapter and go into that.
Thanks,
Pete
