05 SC will not run
Old Jan 11, 2012 | 08:40 PM
howardfx4's Avatar
05 SC will not run
Changed everything but pressure reg. and fuel pump relay truck doesn't get fuel to filter. checked volts at new driver module and have 11.5. Need help!!!
Old Jan 11, 2012 | 09:36 PM
SSCULLY's Avatar
Will not run or will not start ( is it crank no start, no crank, starts and dies ) ?
The fuel pump relay is non serviceable, built into the fuse panel.
Where did you check for power at the FPDM ?
- The white wire at the FPDM will always have power as long as the truck is in the run position, the fuel pump fuse is good, and the fuel inertia switch has not been tripped.
The FPDM controls the fuel pump on the Brown w/ White stripe & Pink w/ Black stripe wires
If you turn the key from off to run ( do not start ) does the theft light go out ?
Do you have an aftermarket security system or remote start installed ?
Old Jan 12, 2012 | 10:51 PM
howardfx4's Avatar
Thanks for info. Do you happen to know what # that fuse would be? I'll check the security light. thanks again.
Old Jan 12, 2012 | 10:53 PM
howardfx4's Avatar
Sorry but the truck cranks but will not start.
SSCULLY's Avatar
Which fuse ?
Old Jan 13, 2012 | 10:52 PM
howardfx4's Avatar
My manual doesn't, show the fuel pump fuse.
Old Jan 14, 2012 | 12:32 AM
SSCULLY's Avatar
The description only refers to the fuel injectors, but the same fuse ( #34 - 20A ) is what is routed to the fuel inertia switch, then to the FPDM.
Which wire did you have power on at the FPDM ?
Does the theft light go out after the key from off to run ( don't start ) and wait 5 sec ?
Old Jan 15, 2012 | 10:30 AM
howardfx4's Avatar
Theft light goes out and fuse 34 has power on each side of the fuse with the key in the ON position.
Old Jan 15, 2012 | 03:21 PM
SSCULLY's Avatar
- The FPDM controls the fuel pump on the Brown w/ White stripe & Pink w/ Black stripe wires
